Additional buttons in OSD
esperado
When you use only your mouse, there is no easy way to luch the left OSD.
The bottom one shows-up when there is a mouse clic near the bottom. It is nice. If, in it where a button to open left osd, it would be nice.
For a good interface, you can try with only a remote, only the keyboard, only the mouse, and find a way to get an easy access to alle the features with those 3 interfaces each alone, don't you think ?
Too, i have a little proble, i don't know if it can be solved. If i'm in wmr9, on my 22" lcd, i have a bad blanking (i can see a clear difference between black on the sides and black in the image: image is allways a little illuminated. Any attempt to correct the blanking with image tuning fails, and there is no interface for wmr in windows cart driver like for overlay.
Edited by esperado
If you have selected (Options>OSD General>) Enable mouse hot tracking in OSD click in the right site from the picture.
This is normaly made by specific tool for your display card who can adjust porch and blanking time for unknown display, but with pnp display this adjustement is automatic, the previous tool can finalize it.
For ATI, it exists ATItool and Catalyst Control Center, similar tool exists for Nvidia.
