some nvidia bugs in 3.9.0
djdul
Hye all,
in VMR9 I have the feature resizing which do not work correctly (move left, right and down but not upper an invisible limit).
the nvidia fix is checked (if not I have a buggy screen; too small one).
I use the cyberlinks codecs with hardware acceleration enable and force bob deinterlace method.
If I can help more.
this bug is on my HTPC number 2 with a MSI NVIDIA wich work with a driver version 162.18.
all is ok in WMR7.
Black screen in overlay.
the system is Windows XP PRO SP2 All update (and more ;) )
More testings :
I'm already in the default OSD skin.
I've tried all codecs :
with overlay = black screen (osd okay)
with vmr7 = screen enlargment okay but image with pixels (no osd)
with wmr9 = screen most beautiful but no enlargment and bug in vertical resizing
nvidia purevideo post process not help.
I try with disabling hadware acceleration (in minotor settings/advanced/"repair" (sorry I'm using french system))
in mode 1,2,3 and 4 it is okay but not very beautifull
in mode 5 and 6 (max) it is okay but resizing buggy...
I've try the 3.8 version and it's the same.
I lost the upper part of the screen and the OSD ! :)
Edited by djdul
Hye all,
in VMR9 I have the feature FULLSCREEN which is buggy.
this bug is on my HTPC 1 & 2 with a NVIDIA(s) and driver version 162.18.
all is ok in WMR7.
Black screen in overlay on htpc#2
the system is Windows XP PRO SP2 All update (and more B) )
same bug in my HTPC #1
overlay ok.
it's a NVIDIA+VMR9+FULLSCREEN BUG ?
If I can help more.
Is it a known bug ?
Edited by djdul
