juhoaj Posted October 22, 2007 Posted October 22, 2007 hello! i have a problem with multiple recordings & live tv. when i have three different recordins, or two recordings & live tv (from different mux:es i think..) DVBViewer goes funky: all recorded .ts files are corrupt (not viewable with any program, including VLC) and the live tv goes black. my system: - audio connected from audio out to plasma audio in (RCA) - xp sp2 (clean install) - DVBViewer 3.8.0 (clean install) - integrated soundmax (adi ad 1888) - 2 x tecnotrend budget C 1500 is this normal. support.zip Quote
Tjod Posted October 22, 2007 Posted October 22, 2007 Are the channels encrypted? Do you have in both cards a CI and CAM and Smardcard? Quote
juhoaj Posted October 23, 2007 Author Posted October 23, 2007 Are the channels encrypted?Do you have in both cards a CI and CAM and Smardcard? all channels are free to air (not encrypted) and there is no CI/smartcard. Quote
Moses Posted October 24, 2007 Posted October 24, 2007 you should tell DVBViewer so! Go to Options->Hardware and untick "Has CI" for your cards. And better tick "open hole transponder". Maybe that caused the problems. Quote
