PlayCD, YesNo in Dialogs via COM
Micha Schumann
Hello,
after all I managed to realize my HTPC with DVBViewer as the "HEART", controlled by a Delphi application that also controls a LCD display and receives remote signals. DVBViewer is really a super software!!!
The last things I dont get up and running are:
1. The Command PlayCD (taken from actions.ini) doesnt work in my installation (3.9.0.0), PlayDVD works.
2. Stereo Sound is much louder than AC3/Surround, is there a way to control that? I use ffyyy Codecs.
3. If a recording is scheduled and I switch off, DVBViewer warns. Can this warning be hooked by an event to be displayed on the LCD also?
4. I have no idea how to control the dialogs with OK/CANCEL oder YES/NO with SendCommand. I definitively need that for my remote.
Any help is VERY appreciated. I am sure I just overlooked things somewhere.
Thanks in advance
Micha
Edited by Micha Schumann
1). "Play AudioCD=8257" works here in 3.9.
3). In DVBViewer Spy (Members section) is it displayed in OSD Window Event and OSD Item Change Event.
