Can't watch encrypted channels
McenterFreak
I have a Technotrend Budget S2-3200 with CI
Unencrypted channels shows fine, but i can't watch encrypted channels
In TT MediaCenter all channels can be viewed without problem, so the CAM works fine
In the option "Has CI" is checked
I use Thor at 1 degree west, Telenor channels
DVBViewer is V3.9
you installed the downloadable technotrend dll with the setup?
did you install the technotrend dll? Go to system controls->software, locate DVBViewer, click on change. The setup allows you to download a list of components at some point. Do that. Now select the support for technotrend cards or similar.
Edited by Moses
Yes, I forgot... just got confused by all that german words in my head like "Systemsteuerung" and so on... but I already recognized it after posting... :bye:
ttBdaDrvApi: The current version number is still 1.0.1.4 from April, 2nd?
Now i feel i am really stupid.
"Go to system Controls>Software"
Where are this options, in DVBViewer? In Windows? Regedit?
It did not ask for it and i think i missed it.
How do i do it next time?
If you got that dll, you did everything correct, already. I was talking about windows... basically the idea was to run setup again. You can do that there or using the link "Modify DVBViewer" in startmenue. On the 4th page the setup asks if you want to download and install additional components. If you enable that checkbox, you'll see a list of components and in that list there is "Support for Technotrend cards" somewhere. This will install the ttBdaDrvApi.dll for you, too. :blush:
Is your problem resolved, now, or do you still can't watch encrypted channels? Does the CAM say anything?
If you got that dll, you did everything correct, already. I was talking about windows... basically the idea was to run setup again. You can do that there or using the link "Modify DVBViewer" in startmenue. On the 4th page the setup asks if you want to download and install additional components. If you enable that checkbox, you'll see a list of components and in that list there is "Support for Technotrend cards" somewhere. This will install the ttBdaDrvApi.dll for you, too. :wacko:
That solved the problem!
Thanks :blush:
Just for info: After that a channel scan is needed
I really don't understand why the installation program dosen't do the trick automatically if a TT card/TT BDA drivers is installed at the installation moment
Edited by McenterFreak
Well you wouldn't have had a problem, if you simply had paid attention and read while installing... :blush:
