Problem uninstalling 3.9
bakerpr
I have a problem uninstalling version 3.9 from my system.
I get the following response "C:\Program Files\DVBViewer\unins002.msg" is missing.
Where can i get a copy of this file or is it possible to uninstall another way?
try to reinstall into the same directory and then uninstall.
Thanks
I thought I had tried tried this previously but seems to have worked this time.
