FF & RW on recordings
chrispazz
I using DVBViewer without much problems but since last two versions (3.8 and 3.9) I have the following annoying problem:
when I am playing a previously recorded TS file, if I try to jump forward or rewing I have not enough time to select the steps. For example I press four or five times to go forward (10 min) but on second press it seems not to wait for my keypresses and jump for only 10 secs (second step).
Is there any way to increase the time DVBViewer wait before executing the jump?
Thank you.
Chris
yes, there is. Have a look at the Tweaks.txt in DVBViewer folder. You will have to edit the setup.xml in configuration folder (have a look at DVBViewer->About) manually.
