accolon Posted October 30, 2007 Posted October 30, 2007 I would be really glad if you could the ability to use Winampt visualizations aswell. And while I'm making sugestions I might aswell do another. I would like the ability to start DVBViewer in OSD mode without starting the tv reception. Thanx beforehand! Quote
Moses Posted October 30, 2007 Posted October 30, 2007 (edited) go to Options->TV/Radio and disable "Tune last channel on start" and then add a -x2110 as commandline parameter to your shortcut(s) to DVBViewer. This will open up the HTPC Menue. If you want something else from the osd, you can look up the ID in the actions.ini in DVBViewer folder. Edited October 30, 2007 by Moses Quote
Tjod Posted October 30, 2007 Posted October 30, 2007 I'm not sure if you know that you can use Sonique Visualisierungen *.svp. Look here or here. If i remember it right it is not easy to integrate Winamp visualizations. I think such a feature will not be available in (near) future. Quote
