disable audio/video bug
derevo
when scheduled recordings are in different transpoders, so only first recording records with disable A/V and when beginning second audio/video enables.
option "default disable AV" is set ON.
how i can avoid this bug?
you need to set disable AV in the recordings. And then you need to stop playback with "Close graph" in the view menu. Don't use audio/video disabled, that produces such a behavior.
  • 2 months later...
now it works with turned of audio/video decompressing.
