aydan Posted October 31, 2007 Posted October 31, 2007 Hi, I'm experiencing hangs (100% CPU load) when I unlock the computer and don't unpause the video before loading another file or exiting the viewer. I then have to kill the process. Dunno if that's a viewer problem or a driver/codec thing. I'll post the support file tonight. Aydan Quote
Zero7 Posted October 31, 2007 Posted October 31, 2007 (edited) I had requested for a solution for same problem. It happens to me if I try to open another video file, while playing one. Ideally, the first one should close and second one should open. System hanging is a major problem I face in this case. If you pause and try to operate forward / rewind, time skip etc DVBV hangs. Edited November 1, 2007 by Zero7 Quote
Moses Posted November 3, 2007 Posted November 3, 2007 you could try to disable "dectect video / audio format" in options->directX. But I can't see anything that's faulty on your setup... maybe it's something outside of DVBViewer. Here it works perfect, so it's not a general bug... you should use a newer support tool next time, the one you use seems to be quite old. Quote
Griga Posted November 3, 2007 Posted November 3, 2007 <entry name="Audiocodec">MPEG Audio Decoder</entry> The MS MPEG audio has a tendency to hang - it's quite outdated. Try another MPEG audio decoder, e.g. AC3 filter, that is already present in your system. you could try to disable "dectect video / audio format" in options->directX It doesn't affect file playback. Quote
aydan Posted November 26, 2007 Author Posted November 26, 2007 I'm using the AC3 filter everywhere now and still get hangs. Just yesterday I accidentally forwarded over the end of a (viewer recorded) mpg-file and the Viewer would hang. And thanks to this it's hard to kill the process so I had to reset my machine. I'll look into this further but if I don't find out anything more would it be possible to get a debug built so I can point you to the right spot? Greets Aydan Quote
Lars_MQ Posted November 26, 2007 Posted November 26, 2007 commandline: -debug But i think its only a indirect DVBViewer problem. More likely there are somewhere in your windows directshow system problems... Quote
aydan Posted November 26, 2007 Author Posted November 26, 2007 I suppose it's time to reinstall my system. Quote
aydan Posted November 26, 2007 Author Posted November 26, 2007 Debug didn't do anything for me. Nothing in there shows anything wrong. I'll try to attach a debugger to the process and find out in which module the error happens. Then we'll see. Quote
Lars_MQ Posted November 26, 2007 Posted November 26, 2007 Debug didn't do anything for me. Nothing in there shows anything wrong. well sometimes it's more interessting what is not shown, instead of what is wrong. But since you being a little secretive about the log, we will never know... I'll try to attach a debugger to the process and find out in which module the error happens. One warning: exspect strange behaviour. serveral codecs do not like the presence of a debugger... Quote
aydan Posted November 26, 2007 Author Posted November 26, 2007 there you go: 26.11.07 18:41:13 CPU ID AMD 26.11.07 18:41:13 CPU Supports FPU 26.11.07 18:41:13 CPU Supports TSC 26.11.07 18:41:13 CPU Supports CX8 26.11.07 18:41:13 CPU Supports SEP 26.11.07 18:41:13 CPU Supports CMOV 26.11.07 18:41:13 CPU Supports MMX 26.11.07 18:41:13 CPU Supports FXSR 26.11.07 18:41:13 CPU Supports SSE 26.11.07 18:41:13 CPU Supports MMX+ 26.11.07 18:41:13 CPU Supports 3DNow!+ 26.11.07 18:41:13 CPU Supports 3DNow! 26.11.07 18:41:13 CPU Target SSE 26.11.07 18:41:13 Start App ----------------------------------- 26.11.07 18:41:14 Hardware.InitDevice Load settings for: SkyStar 2 TV PCI 26.11.07 18:41:14 Hardware.InitDevice Load settings for: Unicast Network Device 26.11.07 18:41:14 Hardware.InitDevice Load settings for: Multicast Network Device 26.11.07 18:41:15 LoadWindowDefs Loading WindowDefFile: C:\Dokumente und Einstellungen\All Users\Anwendungsdaten\DVBViewer Pro\windowdef.xml 26.11.07 18:42:32 params F:\Recorded\Las Vegas_11-25_23-15-01.mpg 26.11.07 18:42:32 AddAVCodecs Using VideoCodec: CyberLink Video/SP Decoder (PDVD7) and audiocodec: AC3Filter 26.11.07 18:42:32 AddAVCodecs - VideoCodec CyberLink Video/SP Decoder (PDVD7) 26.11.07 18:42:32 Add AudioRenderer: Default DirectSound Device 26.11.07 18:42:32 AddAVCodecs - Audiocodec AC3Filter 26.11.07 18:42:32 AddVideoRenderer Add Videorenderer VMR 9 26.11.07 18:42:33 AddAudioCallback Adding callback 26.11.07 18:42:33 CheckMediaType Major Type: Video - Sub Type: ARGB32 Format: VideoInfo2 RGB 720X576, 32 bits 26.11.07 18:42:33 CheckMediaType Width: 720 - Height: 576 26.11.07 18:42:33 CheckMediaType Major Type: Video - Sub Type: ARGB32 Format: VideoInfo2 RGB 720X576, 32 bits 26.11.07 18:42:33 CheckMediaType Width: 720 - Height: 576 26.11.07 18:42:33 QueryAccept Der Vorgang wurde erfolgreich beendet 26.11.07 18:42:33 CheckMediaType Major Type: Video - Sub Type: ARGB32 Format: VideoInfo2 BITFIELDS 720X-576, 32 bits 26.11.07 18:42:33 CheckMediaType Width: 720 - Height: -576 26.11.07 18:42:33 QueryAccept Der Vorgang wurde erfolgreich beendet 26.11.07 18:42:35 Used Filter 0: VMR 9 Renderer 26.11.07 18:42:35 Used Filter 1: Default DirectSound Device 26.11.07 18:42:35 Used Filter 2: DVBV OSD-Source 26.11.07 18:42:35 Used Filter 3: Audio Callback 26.11.07 18:42:35 Used Filter 4: CyberLink Video/SP Decoder (PDVD7) 26.11.07 18:42:35 Used Filter 5: AC3Filter 26.11.07 18:42:35 Used Filter 6: DVB Source 26.11.07 18:42:45 CheckMediaType Major Type: Video - Sub Type: ARGB32 Format: VideoInfo2 RGB 720X576, 32 bits 26.11.07 18:42:45 CheckMediaType Width: 720 - Height: 576 26.11.07 18:42:45 CheckMediaType Major Type: Video - Sub Type: ARGB32 Format: VideoInfo2 RGB 720X576, 32 bits 26.11.07 18:42:45 CheckMediaType Width: 720 - Height: 576 26.11.07 18:42:45 QueryAccept Der Vorgang wurde erfolgreich beendet 26.11.07 18:42:45 CheckMediaType Major Type: Video - Sub Type: ARGB32 Format: VideoInfo2 BITFIELDS 720X-576, 32 bits 26.11.07 18:42:45 CheckMediaType Width: 720 - Height: -576 26.11.07 18:42:45 QueryAccept Der Vorgang wurde erfolgreich beendet Quote
aydan Posted April 24, 2008 Author Posted April 24, 2008 It's still happening on a fresh install of Win2000. I'll try to pin down if it's OS or hardware dependent, since the WinXP on the other machine doesn't do this. Quote
