jcolinpoole Posted November 2, 2007 Posted November 2, 2007 Hi I have just installed DVBViewer pro and thought it would be easy to scan for DVB-T channels with my Pinnacle Hybrid Pro USB stick. (Norway MPEG4 encoding that pinnacle does not support.) However I find it difficult to work our which settings to use in the channel-scan menu. Any help would be appreciated. Quote
Griga Posted November 2, 2007 Posted November 2, 2007 Norway MPEG4 encoding Not yet supported by DVBViewer, particularly AAC audio. But we hope there will be a solution soon. Internal test versions are already working. For scanning try TransEdit (-> members area). The scanner engine already supports AAC / MPEG4. Quote
