Adviceman Posted November 5, 2007 Posted November 5, 2007 I have found that I get the best picture using Neros codecs and Video Renderer = Unchanged. If I use Overlay mixer the picture becomes "unstable". My problem is that when I Start DVBViewer I got no picture. The solution is to choose DirectX in the option menu and turn the Video renderer to Overlay mixer, chose apply and then turn back to Unchanged followed by apply. Irretating and not very convenient! Is there anyone that have an explination or a solution to this problem? Quote
ricabullah Posted November 5, 2007 Posted November 5, 2007 Do you live this issue with FTA channels or the encrypted ones? Quote
Adviceman Posted November 6, 2007 Author Posted November 6, 2007 (edited) Do you live this issue with FTA channels or the encrypted ones? I use the Swedish ComHem (Tv through cable) and I have booth encryptet and none encryptet channels! I have used some other codecs (Nvidia Pure video, ffdshow etc) together with overlay mixer which have worked fine but I don´t get as good picture as I get with Nero Codecs and Video Renderer = Unchanged! Edited November 6, 2007 by Adviceman Quote
ricabullah Posted November 6, 2007 Posted November 6, 2007 (edited) deleted by myself/ no need anymore Edited November 6, 2007 by ricabullah Quote
Lars_MQ Posted November 6, 2007 Posted November 6, 2007 Is there anyone that have an explination or a solution to this problem? Nero is known well for their dvd/cd burning program, but they really suck at codecs. so use another codec and you will not have the problem. Quote
Adviceman Posted November 7, 2007 Author Posted November 7, 2007 The Nero Codec is not the problem. If I use codecs from ffdshow I get the same result with Video Renderer = Unchanged. It´s seems like that the DVBViewer can´t start (No picture) if the Video Renderer is set to Unchanged. Quote
ricabullah Posted November 7, 2007 Posted November 7, 2007 I think you need a clean reinstall of Pro. Quote
