The Gus Posted November 6, 2007 Posted November 6, 2007 Good morning, is there a way to detect if the videotext window is active whiel using DVBV? I'm programmin delphi/com thank you for your support. Augusto Quote
The Gus Posted November 7, 2007 Author Posted November 7, 2007 Sorry to bother, but is there an answer to my question? Thank you again Quote
Tjod Posted November 7, 2007 Posted November 7, 2007 You can detect if the OSD-Teletext is open dvbvspy > OSD Window Event. But i don't know if it is possible to detect the videotext window. Quote
hackbart Posted November 8, 2007 Posted November 8, 2007 you can check if there are teletext pages available via the com interface. If no page is returned you dont receive teletext The simplest and lamest method is to get the current channel and if the teletext pid is 0 or 0x1fff you dont have teletext for this channel. Christian Quote
Lars_MQ Posted November 8, 2007 Posted November 8, 2007 you could check the activewindowID of the windowmanager interface. This only works for the OSD though... Quote
The Gus Posted November 9, 2007 Author Posted November 9, 2007 Thanks for you suggestions! I'll try to code as soon as I can get to the keyboard :-) Quote
The Gus Posted November 15, 2007 Author Posted November 15, 2007 Ok, done :-) My little humble application is quite functional now :-) Thank you all for the useful help! Quote
