extended EPG for Showtime (nilesat)
AjeeB
hi, ppl
I parse EIT data with transedit there is only currect/next even ..BUT this package (showtime) has it's own BOX called SHOWBOX
and there you able to see an extended EPG for a 7 days , I don't know which standad they use
I wonder if we can't modify info to get it work ...
note: same package has audio channel called (Arabic EPG)
BR
cheers
Try to add the Frequency from Arabic EPG to Options>SiehFern/MHW (by Type try all three one after another).
And watch than a channel on this Frequency for 2-3 minutes. May be you have luck and it works.
DVBViewer is limited to the DVB standard as provided by ETSI. Therefore only the EIT is taken into account. Some providers like BSkyB use middleware which is not open source like OpenTV. If you tune to the BBC, all EPG information you'll get from the EIT is current/next. To get the rest, you'll have to buy a skybox..
well, thanks for reply and that was new info.
need find a way to import weekly epg...my solution now I get into there website and find a program
and so adding even with DVBViewer :)
I did not find any xml feeder at website
BR
and thanks
Edited by AjeeB
