ramonchin Posted November 9, 2007 Posted November 9, 2007 (edited) Hi! I have played a mkv (x264) file on two different programs using COREAvc decoder. On DVBViewer Color Space Converter is loaded. On Media Player Classic it's not loaded. I can't see any difference between them on PQ... So why is Color Space Converter loaded on DVBViewer? How can I avoid this? On the other hand, I have Sony Bravia 46X2000 connected by DVI-HDMI... Is that LCD Full RGB (0-255) capable? Thanks. Edited November 9, 2007 by ramonchin Quote
hackbart Posted November 9, 2007 Posted November 9, 2007 Change the output format and/or the used decoder in order to avoid the usage of the color space converter. Christian Quote
ramonchin Posted November 9, 2007 Author Posted November 9, 2007 (edited) Change the output format and/or the used decoder in order to avoid the usage of the color space converter. Christian Actually, VMR7 is the only good renderer in my system. VMR9 (Nvidia Bug checked) doesn't deinterlace the video, and Overlay doesn't produce natural colors... What does convert that filter ? RGB to YUY2 ?? Isn't HDMI RGB compatible? I have Nvidia 7950GT. + last forceware drivers. Edited November 9, 2007 by ramonchin Quote
Moses Posted November 9, 2007 Posted November 9, 2007 (edited) if you don't want that filter, you can just try to uninstall//derigister it lower it's merrit... there are some filters that try to connect to every directshow graph, they can find... But if the picture is ok, you just might want to leave it alone? Edited November 9, 2007 by Moses Quote
