Karill Posted November 9, 2007 Posted November 9, 2007 Hi All I have just now payed and got the DVBViwer & installed it. I did run Mediaportal before and was not satisfied with the program due to the fact that channels the should work fine just didn't & the constant frees when shifting channels and the lack of good support for subtitles. All this is working much better in DVBViewer but there is on thing that i can't understand why in the world can't i find Eurosport UK while scanning for channels even if i have updated with the correct Transponder info found on lyngsat.com for SkyDigital on 28.2E. According to the footprint it should be there and if i use my regular Sky Box i can see it with no problem at all in all weather so it should not be a problem with FloppyDTV/S2 and DVBViewer and yes i have an genuine Sky card that i pay for. Best regards Karill Quote
Derrick Posted November 9, 2007 Posted November 9, 2007 ..maybe your transponder.ini is not up-to-date. Quote
