badtrip Posted November 9, 2007 Posted November 9, 2007 Hi there.. I'm lookiing for a file that should be produced after importing the ini file from Transedit. In CMUV there are a lot of channel related files, for ex; in data base section "tvdatabase's" and in the root folder "channels.bak" All i wanna do is this, First scan with transedit, when needed to, updates with DVBViewer! And i need the file for exporting the updated channellist to my client! As i siad there are lots of files about channels.. Which one should i use? Quote
Moses Posted November 9, 2007 Posted November 9, 2007 channels.dat is the current channel list, channels.bak is a backup from the "previous" one. One thing about transedit: if the channels.dat is missing, updating and sending to DVBViewer won't work. Quote
badtrip Posted November 9, 2007 Author Posted November 9, 2007 Thank you Moses... I'll try as soon as possible Quote
badtrip Posted November 9, 2007 Author Posted November 9, 2007 (edited) Moses that works perfect for me, thanks again Edited November 9, 2007 by badtrip Quote
