Some questions about dvbviewer
carter
Hi! This is my first post and I would like to ask you some questions. First of all I apologize because my English is not very good.
The first question is that if I buy a license for DVBViewer can I install the program on more than one computer? Or I need one license for each computer? My hardware is a Live view trio and I would like to know if it works properly with dvbviwer.
And finally, in the option of server streaming, can I watch one channel in the server and other channel completely different in another computer that is doing streaming?
Thank you for everything.
Edited by carter
Yes, you can.
That's only possible if you have two tuners. If you have just one tuner, the second computer can only view channels on the same frequency as the channel the first one watches.
Just one small thing to make it clear: You can install more than one DVBViewer with your license for your own usage. You can not install the DVBViewer in order to feed "your buddies" or any kind of third party user with your license.
Christian
