villadsen Posted November 15, 2007 Posted November 15, 2007 I have put a shortcut to DV into my Windows startup folder, so that when I boot my HTPC then it automatically starts DV in full screen mode. My problem is that for some reason DV is not the active program in Windows. This means that I have to click on the DV picture with my mouse to make DV the active program and only thereafter can I control DV with my remote control. This is excately not what I wanted because I want to control everything with the remote. Question: is there some commandline or similar that I can use in Windows to force DV to be the active program? Thanks. I have tried always on top, but that does not help. Quote
smv1210 Posted November 16, 2007 Posted November 16, 2007 Setting/Options/General -> Controlbar Popup Delay(in milliseconds) It is set as 100 ms by default. So, just increase the delay until You get desired result. Quote
