ristohopea Posted November 16, 2007 Posted November 16, 2007 Hei there, Playing around I try to get the preview working It works on FTA channels but cant get it working on the channels that are encrypted via de CI. I try to hunt google and find that there is no "preview possible with HD..." but it seems neither possible with CI encrypted channels maybe its stupid question with easy answer but I didnt find the answer..and still hope i understood wrong because im only encrypted channels. Thanks Risto Quote
Moses Posted November 17, 2007 Posted November 17, 2007 in 3.9 it is enabled for encrypted channels, too. But the limitation that only one encrypted channel can be decrypted by one CAM stays. So if you have just one tuner with one CAM, you won't have any use of the preview, sadly. If you have a second tuner + CAM + smartcard, then you should be able to use preview on all the channels. Quote
ristohopea Posted November 17, 2007 Author Posted November 17, 2007 in 3.9 it is enabled for encrypted channels, too. But the limitation that only one encrypted channel can be decrypted by one CAM stays. So if you have just one tuner with one CAM, you won't have any use of the preview, sadly. If you have a second tuner + CAM + smartcard, then you should be able to use preview on all the channels. ok that sad:-( then I need another card+another cam+ another ci...thats a little to much for having preview active. The same applies then also to recording? Risto Quote
Tjod Posted November 17, 2007 Posted November 17, 2007 The same applies then also to recording?Yes Quote
