What kind of bird is FireDTV Viewer
more10
I got the "FireDTV Viewer" with my FloppyDTV. Version 1.0.2.29. Great program, except for the "Program Guide", switching channels takes too long time.
I am trying to get my iMON OEM LCD to work with the viewer, but is clueless since it seems to be different from the DVBViewer.
Can I use any of the tools found in this forum? Which DVBViewer is the FireDTV Viewer?
Thanks
Mårten
the FireDTV Viewer is a special OEM Version of the DVBViewer. It looks very different from the original DVBViewer Pro and lacks many of the functionality. As far as I know you can't use any of the plugins or tools found here for the FireDTV Viewer.
The iMON LCD isn't supported by DVBViewer pro, either, but maybe it will be in the future.
The FireDTV Viewer is not a special DVBViewer version. It a program on it's own which uses the same core like the DVBViewer.
I had the DVBViewer Pro before the FireDTV version.
I only can recommand the pro version because the complete functionality.
regards.
Erik
