KrimReape Posted November 22, 2007 Posted November 22, 2007 Hi If I record a program as a .ts-file, cut the commercials with VideoRedo, and try to convert it into a 350mb xvid file with AutoGK, I get audio out of sync. It's like 0,5sec late, and only noticeable in the later half of the video, but its pretty annoying. What am I doing wrong, or is there a better way to do this? Quote
BenGun Posted November 25, 2007 Posted November 25, 2007 hi, i use this Tools: ProjektX -> demux the .TS file and sync the Audio and Video stream Cuttermaran -> cut the Files and merge Audio and Video Stream AutoGK -> Convert to divx or xvid i have no Problems with this "way", Try it ore take a look to doom9.org, there are some guides sorry for my bad english knowledges, but i think, you understand, what i mean. Quote
KrimReape Posted November 28, 2007 Author Posted November 28, 2007 Thanks for the advice. I found the best combination following: - cut and demux with ProjectX - Make 350mb .avi with StaxRip Perfect sync! Quote
