badtrip Posted November 22, 2007 Posted November 22, 2007 Hi there.. I wanna ask a simple question to you guys.. My computer isn't kinda monster.. I still own my Tİ4200 GPU and 512ram + 2600+ CPU, in one of my computers the question is. When i open a fullHD video, i'm able to watch it with no interference, or freezes.. But with my ss2 card, even if i try opening the FreeTv LUXHD channel, my computer fails, and freezes all the time.. i can watch clearly what is in a file but i cant watch the broadcast.. It doesn't make any sense (for me) Why is that happening? Quote
Tjod Posted November 22, 2007 Posted November 22, 2007 The SkyStar 2 is not able to restive DVB-S2 channels. I don't know if there is a DVB-S HD channel available . On Astra 19,2° E all HD channels using DVB-S2. Quote
ricabullah Posted November 23, 2007 Posted November 23, 2007 (edited) Live broadcast is different story my friend. It needs to get live hardware based deinterlacing of broadcast. If your CPU is making this job, forget to watch fluent watching. If your GPU is making this job, you are lucky. You should watch live broadcast with your 2600 easily. Don't you? (the easiest HDTV/ DVB-S channel is LuxeTV since it is just 1288*1088i.) Edited November 23, 2007 by ricabullah Quote
Dadag Posted November 23, 2007 Posted November 23, 2007 (edited) Try to open Task manager before selecting HD channel, select in performance view (you can also choose the kernel view), then look at the CPU % and RAM %, if one got 100%, your machine cant work correctly for HD channel. For the HD2600 GPU, you can use monitoring feature of the ATItool 0.27 utility to see if GPU really use for DxVA for H264 internaly. Edited November 23, 2007 by Dadag Quote
badtrip Posted November 23, 2007 Author Posted November 23, 2007 The SkyStar 2 is not able to restive DVB-S2 channels. I don't know if there is a DVB-S HD channel available . On Astra 19,2° E all HD channels using DVB-S2. well i didn't count but LUX-HD is being broascasted in alot of sattelites as QPSK... no dvbs2 hardware needed.. (I'm on Eutelsat W3A) Quote
