Anysee E30C plus, no channels in finland?`
kenni_
Hello to all. I'm new here and just installed DVBViewer. But what the heck? No channels?? :arrow: My friend sended me some .ini file wich i copied to DVBViewer's transponder folder. Now, there should be option called (ttv) ? in the transponder list in scan channel option. But it wasn't there. So i tried to scan on allmost every transponder and no channels where still found. Allso tried with no transponder and some freq. range my friend gave me. But still no channels. Could somebody help me with this? yeah, and sorry my bad english.. :blush:
Hope the support.zip file is showing everything u guys need to know about my system.
Hello,
thats true, there only channels for the most populare satellites. therefore it give too many dvb-t networks.
it give two different inis.
one for the complete channels in the channellist which you can import into.
and the other one is for the frequencies/transponders, this file must copy into the Transponders folder there you can find in the configuration folder (DVBViewer -> About -> Configuration folder)
you can test TransEdit http://www.DVBViewer.com/griga/TransEdit%20E/Content.html
and there is the option for Blindscan http://www.DVBViewer.com/griga/TransEdit%2....html#BlindScan
:bye:
