Swedish EPG
Tottes
There is a bug with Swedish EPG in DVBViewer 3.9
When u choose swedish epg and have a look in setup.xml it says <entry name="EPGLanguage">sve</entry>
It should be <entry name="EPGLanguage">swe</entry>
Same with Subtitles
Well you better tell MS they are wrong, because these values are directly from Windows api.
Well i only report what i found to be working since sve dont but swe does
no big problem to change but i found it strange any way
This is for sat-tv sirius and thor
Edited by Tottes
Thank you for the change in 3.9.1.0 anyway ;)
And now dvb subtitles is working auto to
A realy big hug to you all involve
