LCD Smartie plugin for DVBViewer
I've made an LCD Smartie plugin to display DVBViewer status. You can find it here.
It is not as easy to use as the IMon VFD plugin, but is much more powerful and customizable.
thats nice but a little how to to implement the plugin would be nice. if i simply copie the lines in LCD Smartie Screen Status field LCD Smartie crys that he couldnt find a dll that is necessary.
Can ya explain me how to implement the Plugin.
THX
ok got it working. man thats pretty nice is working very proper and the different infos that ill can display are near endless :bounce:
  • 1 month later...
ok got it working. man thats pretty nice is working very proper and the different infos that ill can display are near endless :rolleyes:
Hi Salzhammer,
tell me the secret: How can I get it to work?
Charly
Hi Salzhammer,
Charly
Hi Salzhammer,
did it, just went 1 floor up o:)
Charly
  • 3 months later...
  • 5 weeks later...
i can´t download the plugin. the link doesn´t work. can you help me please?
thx
thx
Have you registered on the LCD Smartie forum? You can see files to download only if you're logged on.
  • 3 weeks later...
Würde es jemand hier uppen ?? Dies wäre doch ganz nett, oder im Member-Bereich. Es muß doch nicht sein, das ich mich erst in einem anderen Forum anmelden muß, oder??
Vielen Dank im Voraus.
CU
Beginner007
  • 2 months later...
wollte mich in dem LCD-smartie-Forum anmelden ging aber irgendwie nicht.
Hat jemand das Plugin für LCD-Smartie-DVBViewer?
Wollte mein serielles VFD Display damit ansteuern.
Danke!
For some reason it seems I can't edit the first message. Does anyone know why?
Anyway, here's the file:
DVBViewer.zip
Edited by barnie_bg
  • 4 months later...
I create after long time research 2 commands line for lcdsmatie
Line 1:
$dll(cut.dll,1,1#12,$dll(warnif.dll,3,$dll(SuperTroca,1,ISO8859-1,$dll(DVBViewer,9,#channelname,))/,$dll(cut.dll,1,2#7,$dll(DVBViewer,9,#currentplaytime,)) $dll(DVBViewer,9,#percentage,)%) )$CustomChar(1,1,3,7,31,31,7,3,1)$Chr(176)$CustomChar(5,2,9,5,21,21,5,9,2)$Chr(133) $dll(tinybar,2,$dll(warnif.dll,3,$dll(DVBViewer,9,#Volume,)/,0),7)
Line2:
~$dll(warnif.dll,3,$dll(SuperTroca,1,ISO8859-1,$dll(DVBViewer,9,#selecteditem,))/,$dll(SuperTroca,1,ISO8859-1,$dll(DVBViewer,9,#TV.Now.title;#Media.title,)))
And you need this for good french characters in Banco.txt:
é|e
è|e
ê|e
ë|e
ï|i
î|i
ô|o
ç|c
ù|u
û|u
â|a
Ã|
This work great, and you can show all informations needeed for HTPC, playing TV and media !
Very thanks barnie_bg for your plugin !
  • 11 months later...
Hello,
I know it's been a while when the last message was posted in the thread but still I'd like to use my MO VK202 display in my media pc. I have DVBViewer running and try to use Smartie to get it to run with it. I have installed Smartie and copied the plugin which I downloaded from the Smartie forum as it was mentioned on different spots. But still I get the error message that the plugin cannot be found (#126). What could be wrong? I already have followed the suggestions to install all necessary DLLs and Framework 3.0 but no difference.
Can anybody help me please?
THX
