Help using Conditional Access Module
Seany463
Hello, I was wondering if anyone could point me in the right direction when it comes to my CAM for DVBViewer. I recently got a CAM for using my subscription smartcard in DVBViewer, however the option to "Show CAM" under the "View" tab in DVBViewer 3.9.0.0 is shaded out & I cannot select it. Do I need some sort of plugin to make DVBViewer recognise my CAM?
I am using DVBViewer 3.9.0.0, TechnoTrend S3200 with budget CI & a T-Rex 4.1 Dragon CAM (fully loaded).
Many Thanks.
did you install the addiional technotrend dll from the viewer setup ?
I did not, no. When I installed DVBViewer I had a hauppauge hvr-4000 so there was no need. I have now re-installed DVBViewer and can see what you are speaking about. Thanks for the quick response.
Everything working now, thankyou very much.
