Can't get selected File in OSD using Commands.ini
FEFX
when I try to get the filename of the selected osd-item, as described in com-interface-documentation,
I always get the first file in my recordings-folder - it does not matter which recording is actually selected.
I'm using Dvb script:
[RecCmd]
Test=ShowFilename.vbs
My vbs-script "ShowFilename.vbs", taken from com-interface-documentation:
sub main(Filename)
osd.showinfoinTVpic Filename,5000
end sub
As an example, I select a recording called "Auf den Punkt", hit commands, select "Test"
A message appears: "D:\Aufnahmen\11-21_12-12-00_TW1_ORF SPORT PLUS.ts" which is the first file in D:\Aufnahmen when viewing files by name.
The message SHOULD have said: "D:\Aufnahmen\12-01_16-45-01_NDR FS MV_Auf den Punkt.ts"
What is wrong here?
Thanks
Felix
Edited by FEFX
