channels with multiple audio streams
Benarty
I've changed the configuration of our mediacenter.
4GB ramdisk with battery backup for windowsXP pro+cyberlink powerdvd + all drivers + DVBViewer (875MB left)
Radeon HD2600Pro
There are channels that support multiple channels.
I tried to erase the langauges that I don't need but and when I click on the update button, fine.
Then I have the englisch or german as default.
But: as soon when I choose the channel then DVBViewer loads the original channels again.
So..in this case... pol, ger, eng.
Is there no way to just keep one channel in such case?
ps. windowsXP pro now and shutdown with remote still not working (it just closes DVBViewer)
Via OSD exit works fine, system shuts down.
Edited by Benarty
You can charge the Default audio streams put your preferred one on the first one.
If you did not lick it you have to disable Channel>Auto-Update Channel.
channels...auto update channels?
ah,... I use DVBViewer as HTPC so will have to switch to windowed.
