On 3.9.1.0 don't work OSD Menu!
voodoo
Voodoo, check if you have any skins installed in the main DVBViewer folder. Look for "OSDSkins" folder in the DVBViewer folder and it should contain a "Default folder" which should have an "images folder" with icons in. Alternatively, go into "Options" in "DVBViewer" itself, scroll down to "OSD General" and "OSD skins". Make sure "default" is highlighted in the right hand screen, "apply" and then check again to see if your OSD appears. You can always download more skins from the DVBViewer members area and install them in the OSDSkins folder in the same way as the original "default" folder is installed so DVBViewer can read them.
Good Luck!
Gae
Edited by Gae41
that's normally the kind of "bug" report, which does not even deserves an answer.
But my guess based on the extensive informations you gave:
your monitor is not turned on, please make sure the cables are plugin correctly and the monitor is turned on.
please don't be so rude - it's christmas time. :bounce:
