Steve-Austin Posted December 5, 2007 Posted December 5, 2007 (edited) Hi, I'm from Belgium and we use "special" frequency's. For example on my network (DVB-C) we have: 118500 126500 134500 142500 290000 298000 306000 314000 322000 330000 338000 346000 362000 370000 378000 386000 466000 Frenquency like 118500 is impossible to set in DVBViewer, I tried to modify the ini files, but it doesn't work. I already have the old frequecy settings. And if I try a manual scan with this value, DVBViewer ignore it. Edited December 5, 2007 by Steve-Austin Quote
Steve-Austin Posted December 5, 2007 Author Posted December 5, 2007 Hi, I'm from Belgium and we use "special" frequency's. For example on my network (DVB-C) we have: 118500 126500 134500 142500 290000 298000 306000 314000 322000 330000 338000 346000 362000 370000 378000 386000 466000 Frenquency like 118500 is impossible to set in DVBViewer, I tried to modify the ini files, but it doesn't work. I already have the old frequecy settings. And if I try a manual scan with this value, DVBViewer ignore it. I found the problem ... I changed here C:\Program Files\DVBViewer\Transponders but in fact, I had to change there C:\ProgramData\CMUV\DVBViewer\Transponders Quote
