wheelie Posted December 7, 2007 Posted December 7, 2007 (edited) Hi, After happily using DVBViewer Pro for some time I decided to create a Home Theatre PC which will do nothing but run my TV cards. My problem is that when I go to install DVB Pro 3.9.1.0 (or even 3.9.0.0) I get an error "cannot import dll:C:\TEMP\xx-XXXXX\unzipper.dll" and the install stops. The sub-folder xx-XXXX changes name every time I run setup.exe I am using WinXP SP2 Dvico DualDigital DVB-T TV card Celeron 2.6 512 mb SDRam nVidia FX5200 256mb Video card any suggestions please? cheers Edited December 7, 2007 by wheelie Quote
wheelie Posted December 9, 2007 Author Posted December 9, 2007 Well it seems I have everyone stumped. I managed to find a workaround. I downloaded the old DVB 3.2.6 from the archives and it installed fine. i then installed 3.9.1.0 on another computer where I to no error message. I then copied the DVBViewer folder containing v3.9.1.0 over the 3.2.6, set it up and now all works fine. I would still like to know why v3.9.1.0 won't install on my media PC Quote
dk1 Posted December 3, 2008 Posted December 3, 2008 Well it seems I have everyone stumped. I managed to find a workaround. I downloaded the old DVB 3.2.6 from the archives and it installed fine. i then installed 3.9.1.0 on another computer where I to no error message. I then copied the DVBViewer folder containing v3.9.1.0 over the 3.2.6, set it up and now all works fine. I would still like to know why v3.9.1.0 won't install on my media PC Exactly the same problem here with latest version. Installer is bugged ??? help ! Quote
Tjod Posted December 3, 2008 Posted December 3, 2008 Installer is bugged ???In Think no, that must be a special problem on your system.Otherwise we would have 10 or more Topics about this problem. Quote
