Elv1s Posted December 7, 2007 Posted December 7, 2007 Hi, I want to playback some Media Files from a encrypted Safe Guard easy Private Disk Container. Normally every Application recognizes the SGE Container as a removabale Disk or another Harddisk once it is mounted and I am able to access Files stored on it. But DVBViewer does not See my Mounted SGE Container. The corresponding Drive is just not listed under MyComputer if I try to browse to the files if Use the Option "Open Video" in DVBViewer. How Can I access my files directly from the container without having to copy them to my local drive first? Every other application is able to recognize the SGE Container only DVBViewer seems to have troubles. Quote
BertM Posted December 9, 2007 Posted December 9, 2007 Could it be something like: Options->Movies->Add Virtual path ? Quote
Elv1s Posted December 13, 2007 Author Posted December 13, 2007 Could it be something like: Options->Movies->Add Virtual path ? Yeah Bert, but if you try to Brows to the Mounted Drive, that Drive is not available under "MyComputer" Only the physical Hard Drives are listed not the mounted virtual Drives. But if I open "MyComputer" directly in Windows Explorer, the Mounted Drive is listed just the same way as a physical drive (as it is supposed to be). I hope it is clear what I mean. Quote
