Scheduler: Executing an action/command on exit
Zazza
Hi (again)...
I've read (on another forum) that's possible to execute an action (or command) just after DVBViewer is closed using the Scheduler plugin.
So, I've downloaded and copied the scheduler.exe and write a scheduler.ini config using a user's example and placed them in the root folder of DVBViewer.
Here it is:
[scheduler]
Username=xxxx
Password=xxxx
[General]
Version=2.0.0.0
[frmScheduler]
Left=1255
Top=14
Width=336
Height=319
cbAutoSchedule=All
cbScheduleOnStart=1
cbScheduleOnClose=1
cbScheduleOnSuspend=0
cbContinueWith=Default
cbCloseOnShutdown=0
cbDontTune=1
cbAutoMinimize=1
udLeadTime=3
edSpecialParam=
DVBStartDelay=2000
DVBCloseDelay=2000
ScheduleDelay=1500
DVBRestartOnResume=0
Launcher=Scheduler.exe
LaunchedFile=DVBViewer.exe
cbStartMinimized=1
edBefore=
edAfter=D:\DVBViewer\test.cmd
edSleepTime=1000
RunAfter=0
The command I'd like to execute is the one in bold.
However, scheduler simply does nothing: test.cmd is not invoked. I've tried 2.0.0.0 and 2.1.0.0 versions with same results.
What am I doing wrong?
Thanks.
It will only be executed, if DVBViewer has started by a task before.
I don't really know the reason for it. But you can find it in a very old topic in this forum. It was a user request.
Today it might be obsolete, so I might remove the restriction.
Sorry Hartwig... I don't get it... You mean that you could modify your plugin to execute a command EVEN WITHOUT starting DVBViewer with a task?
