patti Posted December 8, 2007 Posted December 8, 2007 (edited) Hi, is it possible to use your remote controller to eject the dvd drive in DVBViewer? I looked in options-input but there is no "eject" command to map to a keyboard or remote button. Going to HTPChome-TheMovies and then using eject function from menu is clumsy to use. Thanks, P Edited December 8, 2007 by patti Quote
Innuendo Posted December 8, 2007 Posted December 8, 2007 options -> input choose your prefered section and then press add give your new function a name and select "eject" from drop down box on the right innu Quote
patti Posted December 9, 2007 Author Posted December 9, 2007 Thanks options -> inputchoose your prefered section and then press add give your new function a name and select "eject" from drop down box on the right innu Quote
