baja Posted December 11, 2007 Posted December 11, 2007 In "Options" menu under "General section" There is no HTPC mode, That section is empty. How you activate HTPC mode? And how you turn on OSD menu and turn off, I do have just basic DVBViewer pro screen. (ver. 3.9.1) Quote
Tjod Posted December 11, 2007 Posted December 11, 2007 HTPC mode is moved in the Tweaks.txt. But the "HTPC mode" has nothing to do with the OSD. To open the OSD-Menu try [Esc] Quote
baja Posted December 11, 2007 Author Posted December 11, 2007 HTPC mode is moved in the Tweaks.txt. But the "HTPC mode" has nothing to do with the OSD.To open the OSD-Menu try [Esc] Thanks Quote
