epg over network
Hi!
I have problem that EPG data that is imported with myXMLTV.exe is not transfered to clients...
It would be great if you could fix it :)
thx
that is no bug. EPG Data is normaly recieved from the TS Stream, which is streamed completely over the network, so every client has to maintain it's own epg (like it has to maintain it's own channel list and so on). In fact DVBViewer client doesn't even know a difference between the network devices and the real devices...
If you want to have epg on the clients, you'll need to import it on every client or you can distribute the epg.dat from your server.
