misterju Posted December 13, 2007 Posted December 13, 2007 Hi i just bought program some days ago, i can tune channels and the program overall is working fine, but i'm having 2 problems: I cant record, when i try to record i receive the message i have to register my user password, i enter them and the program shutdown, and when i try to record again i receive the same message... Also, i cant see the EPG channel information, "epg not available" in all channels, what can i do ? Thanks for any suggestions in advance. Quote
Lars_MQ Posted December 13, 2007 Posted December 13, 2007 please deinstall the viewer completly including programm folder and userdata folder to get rid of potential residue of a not legal previous installation. Reinstall it and make sure you input the Userdata, you received upon purchasing the Pro, correctly during installation. Also verify your dvb provider does provide EPG. Quote
MichaelJ Posted December 17, 2007 Posted December 17, 2007 I had the same issue. If you are using Vista please make sure you remove all traces from DVBViewer not removed by the un-install script - i.e. in the register database, and in AppData and ProgramData folders ... Michael Quote
MichaelJ Posted December 17, 2007 Posted December 17, 2007 Lars, In private support I was accused for the same thing - i.e. to have a non-legal version on my PC - causing DVBViewer to request username / pasword. This was NOT the case, so my conclusion is that something is not working correctly under Vista. I'm sure that the un-install script doesn't work, it leaves data in the user DataApp folder and/or in the ProgramData folder, and it doesn't remove register database data. Do you have experience with DVBViewer on Vista? Michael Quote
