Duplicate Add/Remove Program entries...
antdude
Might be a bug?
Two days ago, I upgraded v3.5.0 to v3.9.1.0. I noticed my Windows XP Pro. SP2's Add/Remove Programs list has duplicate DVBViewer entries (ignoring T.E. one since that is fine and I do have it installed in another folder/directory): DVBViewer Pro v3.9.1.0 and DVBViewer v3.5.0
Also, why does newer version have "Pro" in it? Did I download and install the wrong product? They looked identical in terms of features (I only use the DTV stuff).
DVBViewer Pro has been DVBViewer Pro for a long time, now (maybe it always has been called pro? I can't remember). So it's the right product.
The duplicate entries are correct, sadly. There were some changes in the setup...
So to avoid it, I need to uninstall all and reinstall one and can't do overinstall/upgrade with newer versions?
