Integrate Dvb Viewer in Media center
olixelle
Hi all :)
we are a young french company that provides custom media center applications for handicapped and old users.
We are looking for a TV viewer with recording & time shifting capacities to include it in our applications.
We recently bought DVBViewer and it looks to match to our needs.
I saw that several tools are provided in the member seciton to customize DVBViewer.
Could u please tell me how to custom it in order to fullfill our requirements:
- start DVBViewer without window's border
- channel +/-, go to channel X
- start / stop record
- start / stop time shifting
- hide / show OSD information
- custom OSD appearance (OSD menu editor should be the right tool :)
As u probably understood it, we plan commercial uses of DVBViewer (i will contact u later about this purpose) but i'd like to be sure that DVBViewer is the right product.
For information, our application is build in .net
Thanks in advance for ur help !
Best regards
Olivier ZIMMERMANN
It's possible to send every action from the actions.ini (in DVBViewer folder) to the DVBViewer via the COM Interface. I managed to use the COM Interface of DVBViewer with a J# Application. There is even a special command to set a certain channel number.
Maybe you should have a look at the COM interface documentation (member section) and OSD Editor (not only the OSD Menu Editor).
It's possible to send every action to DVBViewer with command line parameters (-x# where # is the action number from actions.ini), too.
  • 3 weeks later...
I would like to know that too...
Or where/how I can remove it completely ?
The only thigh i know the DVBViewer have a small border.
View > Hide All or use Fullscreen.
ok thanks !
here is what i tried:
Me.MyManager.SetSetupValue("General", "HideMenu", "1")
Me.MyManager.SetSetupValue("General", "Statusbar", "0")
Me.MyManager.SetSetupValue("General", "Toolbar", "0")
Me.MyManager.SetSetupValue("OSD", "UseOSD", "0")
Me.MyManager.ApplyConfig()
but doesnt apply...
another question: i tried to start a record using this:
Me.MyManager.SendCommand(22)
but it doesnt work too....
please :bounce:
it is not 22 but 34... it works now
