DVBViewer - Vista X64 - 4GB RAM
Huigie
Before I start blaming the rest of the world.. is DVBViewer compatible with Vista x64 on a machine with >4GB of RAM installed?
DVBViewer istself is compatible with Vista 64 (not all of the addons work 100% in vista and 64Bit drivers for the DVB devices often are a problem, too). As far as I know it makes not much difference for the applications how much RAM is installed. DVBViewer is a 32Bit application and as such can handle 4GB RAM at maximum, Vista 64 does (or better "must") handle that. I think it shouldn't make more problems if there is more than 4GB RAM installed in the system.
Edited by Moses
Thx Moses. I need a working DVB-C solution for my Vista X64 + >4GB RAM system. Any idea what to get? I got a Twinhan atm but that does not work.
