does it work with Pinnacle 7010ix?
derevo
and it is first dvb-s tuner with pci express bus.
i did not see other dvb-s pci express tuners.
all new motherboards has only 2 or 3 old pci bus.
Edited by derevo
  • 1 month later...
YES ! it works :)
On Win Vista the drivers installed automagicaly over the vista update function.
DVBViewer shows up 4 Devices (2x DVB-T, 2x DVBS)
Very nice piece of Hardware!!
  • 11 months later...
YES ! it works :angry:
Hello,
which drivers did you install? We did not manage to get it up and running with DVBViewer! Any tips are very appreciated!
Micha
Hello,
Micha
What is your system i.e. XP/Vista 32 bit/64 bit? If you let Windows update find the drivers it should find the correct ones.
