Deleting recordings
chrispazz
Hello. Since last upgrade to latest version I noticed that if I delete a recording from the OSD menu, it is deleted from the list but the TS file is not deleted from the disk.
Is this a DVBViewer issue?
Thank you
Chris
it's working here. Is the file in use? Has the DVBViewer sufficient rights to delete the file?
Yes, rights seems to be ok.
Could it be that I tried sometimes to delete the file while still viewing it?
