skystar2 with virtualdub
larouche
for capture and conversion for DIVX i can use virtualdub, but i want use it with skystar2 and capture driver if it's possible.
thanks for help me.
That's definitely not possible. The SkyStar2 is a DVB card, so there is nothing to capture. The DVBViewer (or other DVB software) just saves the original digital stream from the satellite (with slight modifications in the header) to the disk.
Bye, Oliver
