PerM Posted December 27, 2007 Posted December 27, 2007 Hello, I'm having troubles exporting the channels from TransEdit 3.1.3.0 to DVBViewer Pro 3.9.1.1; I keep getting the message box saying "Sorry - cannot export since DVBViewer Pro/GE is not present.". It all worked fine before I reinstalled Vista. I've tried running both program as admin (thought it might be a security issue), but that didn't help. TransEdit is installed in the same folder as DVBViewer Any ideas on what the problem could be? Thanks, P support.zip Quote
hdv Posted December 27, 2007 Posted December 27, 2007 Hello, is there a channels.dat in the configuration folder? If not use the attached dummy channels.dat and put it into the configuration folder (DVBViewer -> About -> Configuration folder). channels.zip Quote
PerM Posted December 27, 2007 Author Posted December 27, 2007 Thanks, that was the problem. I skipped the channel search in DVBV this time since I never got it to work in the last installation... Cheers, P Quote
