scorpione1117 Posted September 25, 2003 Posted September 25, 2003 Hello I would like know where I can find (bay) a Remote Control and a Receiver for SS2 card (Technisat). Thanks Quote
Klausing Posted September 26, 2003 Posted September 26, 2003 please explain it a little bit what you want to do remoute ... and what you mean with Reciver for SS2? Quote
Guest Oliver Posted September 26, 2003 Posted September 26, 2003 I think he's looking for a WinLIRC remote and infrared receiver. @scorpione1117: You should have a look at Ebay. Bye, Oliver Quote
scorpione1117 Posted September 28, 2003 Author Posted September 28, 2003 Yes, I look for a WinLIRC infrared receiver (Hardware) to be connected to SS2-Card and so through a Remote Control to use the programs. Thanks Quote
Guest Oliver Posted September 28, 2003 Posted September 28, 2003 Usually the receiver is connected to a COM-port. Then you must configure your remote control with the WinLIRC software. After that you can use the remote with every software supporting WinLIRC. Bye, Oliver Quote
scorpione1117 Posted October 4, 2003 Author Posted October 4, 2003 Hello I found the WinLRC software but I need a infrared receiver to connect at the COM port and a remote control to (pilot) direct it. Thanks Quote
