command line options
jekuli
I would like to start the DVBViewer into video selection OSD screen when started.
I have looked/searched, but there does seem to be good documentation for DVBViewer command line options.
I have seen following switches mentioned:
-c
-reset
-x
Are there some other switches available?
Or how do I pass along command to change into this OSD screen when started?
(from actions.ini file this would be the command: OSD-Show Video=8204)
To answer myself, and keep this ignorant questions here for other newbies....
Start up the DVBViewer with command line switch -x[command number]
The command numbers are in the actions.ini file in the DVBViewer folder.
Edited by jekuli
