galmok Posted December 30, 2007 Posted December 30, 2007 I have recorded a show (in mpg) that starts in 4:3, switches to 16:9 during commercials and then back to 4:3. Now, what I see is this: DVBViewer starts in 4:3 without black borders. No problem. Commercials show (16:9) and DVBViewer scales the image to fit in the display (puts black borders on top and bottom of the image). No problem. I resize the window by selecting 100% zoom. DVBViewer rescales the window to be 16:9 and the image fits snugly inside. Still no problem. Then the show continues (in 4:3) and now DVBViewer scales the image to 4:3 and thereby adding black bars to the left and right of the image. Reasonably enough. DVBViewer reports the image to be 4:3 Then I again resize the window by selecting 100% zoom to get rid of the black bars but this part fails. DVBViewer keeps the black bars on the left and right side. I cannot make the bars go away again. I expected the bars to disappear and the window to shrink to fit. I just can't make the window shrink regardless of what I do. Quote
hdv Posted December 30, 2007 Posted December 30, 2007 Hello, have you set in Settings -> Aspect Ration -> "Auto" + "Autosize" ? With a testfile 4:3 -> 16:9 -> 4:3 etc. play without problems, and the window is always without black bars. Quote
galmok Posted December 30, 2007 Author Posted December 30, 2007 Hmm yes, I found the option and as you suspected, it was disabled. But I still dont understand why (with auto resize off) a 4:3 display starts out without black bars and later ends up with black bars without having changed any options in-between. But ok, it seems autoresize does what I want and therefore no code change is necessary (was just very confused). :-P Quote
