paul01609 Posted January 1, 2008 Posted January 1, 2008 hi every one complete newb to DVBViewer,i have skystar hd card that sucks with orginial software so i bought DVBViewer to try does the software support cams i have diablo and dragon cam,what settings would i have to change for cam to work?its for the digitalb package which i have a legit card for. many thx Quote
Moses Posted January 1, 2008 Posted January 1, 2008 did you install the support for technotrend cards while installing DVBViewer? The skystar HD is produced by technotrend and the CI is used in the same way by DVBViewer, so you'll need the same *.dll for this card as for other technotrend ones. If it doesn't work, be sure that the ttBdaDrvApi_Dll.dll is in the DVBViewer folder, otherwise run setup again and install support for technotrend cards. Quote
paul01609 Posted January 1, 2008 Author Posted January 1, 2008 did you install the support for technotrend cards while installing DVBViewer? The skystar HD is produced by technotrend and the CI is used in the same way by DVBViewer, so you'll need the same *.dll for this card as for other technotrend ones. If it doesn't work, be sure that the ttBdaDrvApi_Dll.dll is in the DVBViewer folder, otherwise run setup again and install support for technotrend cards. thx moses for the reply support do you mean the software for the technotrend card?the only software i have installed is the one that came with the card and ci slot,the software what i installed its a load of crap it locks up my computer some times and i have to restart it. Quote
Moses Posted January 1, 2008 Posted January 1, 2008 No, I'm talking about the DVBViewer pro setup. You should have a link in your startmenu "Modify DVBViewer Pro Version 3.9.1", click on it and the setup will start. On the fourth page, there will be the option to download additional components, enable it. The next page will show a list of components, select "Support for Technotrend cards", on my computer it's the very first component, then completey the rest of the setup and everything should start working. Quote
