carnt find digitalb plz help
paul01609
i only seem to be able to pick up aprox 22 chanels on 16E when i do a scan,im trying to get all the digitalb channels is there a manuel way of scanning for them?sorry but i am totaly new with this software
11055v 27900 3/4
11094v 27900 3/4
11449h 27500 7/8
hi there get yourself an updated 16e transponder ini file from hxxp://en.kingofsat.net/satellites.php.replace the one in your transponder folder.
incidentally the transponder folder you need to alter is not the one in the DVBViewer folder.
it is found in documents all users application data cmuv.you may need to show hidden files to see it.hope this helps
cazhug
cazhug
many thx m8 all sorted now,rather than start a new thread is it possible to move my dish with my skystar hd card with ci addon?ita a Moteck SG-2100A motor
yes m8 i use the moteck with a hauppauge dvb-s2 card.there seems to be a problem going west using go to angular so i use the positioner control.
this is how i do it.open channel editor and edit diseqc.input lat and long,close this and then open channel scan.enter a name in root ie 19e.then choose transponder.
select use positioner and in this case choose position 2.then scan.
positions in the version of moteck i have are 1=13e,2=19e,3=16e,7=1w,14=30w 18=28.2e
once youve got your sats in just clicking on a programme will take the motor to that sat.
cazhug
thx m8 you have been a great help,will try it later as i have to leave my reciver on digitalb so they can update my card,they have given me wrong package :bye: so im waiting for them to change it
